4GB LPDDR4 RAM configurations for imx8m mini
sakizci
We designed a custom imx8m mini device and used 4GB LPDDR4 RAM.
Micron MT53D1024M32D4DT-053 AIT:D (1Gb x 32)
How can I use 4GB LPDDR4 RAM as it should be?
Can you share an RPA file for 4GB LPDDR4?
What should I change in U-boot?
Can you share with me if there is Kernel Patch for U-Boot?
Thank you
Tags (3)
nxf63675
Hi sakizci,
You can use the RPA that is on the website by configuring correctly the file, please see the link below:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX8MMini-m845S-DDR-Register-Programmin...
For the U-boot changes that you need to do this depends on the configuration that you do, in the DDR tool guide you can check how to build a custom U-boot.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8M-Family-DDR-Tool-Release/ta-p/110...
Israel.
