1.2GHz products of i.MX6D/Q
933件の閲覧回数
torus1000
Hi.
I guess at least 3 modifications required for 1.2GHz i.MX6D/Q.
    a.  add "ldo_active=on" in u-boot cmdline
    b.  LDO input range: 1.4- 1.5V
    c.  LDO output: 1.275V
*Where CPUFREQ driver read the dtb to support setpoints for b. and c. which programmed in the <kernel>/arch/arm/boot/dts/*.dtsi.
(Q1) Is there any application note or design guide which described tips to modify software and hardware for 1.2GHz i.MX6D/Q?
(Q2) Where can I get the official data sheet for 1.2GHz i.MX6D/Q?
I heard datasheet addendum for it long time ago.
(Q3) Which PMIC/voltage setting scenario as following is recommend for 1.2GHz i.MX6D/Q?
    d. MMPF0100F0/F1..FAxxx: SW1 supply 1.375V to the ARM core at early boot then switch SW1 to 1.4V output.
    e. MMPF0100NPxxx: otp programmed as SW1 supply 1.4V and DCD customized to 1.2GHz for ARM clock.
Can anyone help me?
ラベル(2)
タグ(3)
827件の閲覧回数
Hi torus1000
I believe these 3 modifications are correct.
1 unfortunately I am not aware of such documents
2 please create service request
3  "d"
828件の閲覧回数
Hi torus1000
3  "d"
