The Yocto Project is open-source, so anyone can contribute. No matter what your contribution is (bug fixing or new metadata), contributions are sent through patches to a community list. Many eyes will look into your patch and at some point it is either rejected or accepted. Follow these steps to contribute:
$ git config --global user.name "Your Name Here"
$ git config --global user.email "your_email@example.com"
fsl-community-bsp $ repo init \
-u https://github.com/Freescale/fsl-community-bsp-platform \
-b master
fsl-community-bsp $ repo sync
Create local branches so your work is *not* done on master
fsl-community-bsp $ repo start <branch name> --all
Where `<branch name>` is any name you want to give to your local branch (e.g. `fix_uboot_recipe`, `new_gstreamer_recipe`, etc.)
value by one) either the `PR` or `INC_PR` value
sources/meta-fsl-arm $ git add <file 1> <file 2>
sources/meta-fsl-arm $ git commit
On the commit's log, the title must start with the filename change or introduced, then a brief description of the patch's goal, following with a long description. Make sure you follow the standards
(type ` git log --pretty=oneline` to see previous commits)
sources/meta-fsl-arm $ git format-patch -s --subject-prefix='<meta-fsl-arm][PATCH' -1
Where the last parameter (`-1`) indicate to patch last commit. In case you want to create patches for older commits, just indicate the correct index.
If your patch is done in other folder, just make sure you change the `--subject-prefix` value.
git send-email --to meta-freescale@yoctoproject.org <patch>
where `<patch>` is the file created by `git format-patch`.
fsl-community-bsp $ repo abandon <branch name>
