The D-PHY PLL (in the red circle in the picture below) is the PLL that drives the MIPI Clock lane. It must be set in accordance with the video to be sent to the display.
The video bandwidth is calculated with the following equation:
Pixels per second = Horizontal res. x Vertical res. x Frame rate x Bits per pixel
Taking as example the 1080p60 OLED display RM67191:
Pixels per second = 1920 x 1080 x 60 x 24
Pixels per second = 2985984000 = 2,98Gpixels/sec
The Display pixel clock can be obtained on the display driver. In this example for RM67191, the pixel clock is 132Mpixel/sec, see file:
panel-raydium-rm67191.c\panel\drm\gpu\drivers - linux-imx - i.MX Linux kernel
Line 530:
.pixelclock = { 66000000, 132000000, 132000000 },
Or the number can be obtained with the following equation:
pixel clock = (hactive + hfront_porch + hsync_len + hback_porch) x (vactive + vfront_porch + vsync_len + vback_porch) x frame rate
pixel clock = (1080 + 20 + 2 +34) × (1920 + 10 + 2 + 4) x 60
pixel clock = 132000000 (rounded up)
The mipi-dphy bit_clk is the output clock and is calculated on file sec-dsim.c (line 1283):
sec-dsim.c\bridge\drm\gpu\drivers - linux-imx - i.MX Linux kernel
Bit clock can be calculated with the following equation:
bit_clk = Pixel clock * Bits per pixel / Number of lanes
In the case of 1980p60 (Raydium display), It is:
bit_clk = pixel clock * bits per pixel / number of lanes
bit_clk = 132000000 * 24 / 4
bit_clk = 792000000
Other important timing parameters like 'p', 'm', 's' are obtained on the table in the following header file:
sec_mipi_dphy_ln14lpp.h\imx\drm\gpu\drivers - linux-imx - i.MX Linux kernel
