Porting Guideline Application from JN5169 to K32W041/61 and JN5189
kostas1
Hi NXP Team,
In the company i work on we use a JN5169 module on several products. We are currently interested on introducing a multi protocol functionality into our products.
I would like to ask if you offer any documentation guidelines on how to port an application from JN5169 to K32W041/61 or from JN5169 to JN5189
Thank you.
Tags (4)
estephania_mart
It is most likely that it will be release through the first days of may.
I would recommend you to keep an eye on the web page the first days on May and verify if the release is made that week.
Hope this helps.
Estephania
estephania_mart
The JN5189 does not support multiple protocols but the K32W does support several protocols, still , the K32W is being released so currently we do not have a guide for your needs.
Sorry for the inconveniences this might cause you
Estephania
kostas1
Hi Estephania,
Thanks for your response.
Do you know when the K32W will be officially released? In NXP website there is no much information such as development boards etc.
estephania_mart
Hope this helps.
Estephania
kostas1
Thanks Estephania.
Have you got any plans to release the K32W chip as a module like the JN5169-001-M00-2?
estephania_mart
The boards come similar to the JN5169 as they use a base board and some module boards. Still, please check the available boards an devices in May.
Estephania
