Is there any way to generate encrypted firmware for JN5169 ?
978 次查看
hirenvirapara
Can anyone please let me know if is any way to generate encrypted firmware for JN5169.
-I just want to apply some user-specific security on plain firmware so I can assure that loaded firmware in JN5169 is trusted.
Thanks :smileyhappy:
  • JN
标记 (1)
897 次查看
mario_castaneda
Hi Hiren,
It will depend on the memory that you want to use. Internal or External Flash
Internal Flash
If you program the JN MCU you could enable the code protection.
Please look at the 3.7 Set the Device Configuration and AES Key
JN51xx Production Flash Programmer User Guide
External Flash
Please look at the https://www.nxp.com/docs/en/user-guide/JN-UG-3081.pdf
Please let me know if it helps.
Mario
