I have tried working upon sample code of zigbee 3.0 coordinator and router from SDK version 2.0 but couldn't rectify the code to generate any data/message for transmission from coordinator to router and vice versa. I am using MCUXpresso IDE, Please let me know which functions from which file can be used for data transmission and from where we can call them. as these examples are command based.
Hi Sir,
We are using FRDM-KW41Z board and SDK version is latest only, though I had already downloaded SDK_2.2.0 for FRDM-KW41Z board, and already gone through that document (AN12061) but found nothing about data transmission
and also gone through many document but did find any help.
Please let me help regarding data transmission.
Thank you for contacting NXP support.
I have the following recommendations:
In the SDK documentation you will find the AN12061 that describe in a more detailed way how to use the examples of the Coordinator and Router. This documentation can be found on the following path sdk_documentation->docs->wireless->ZigBee->ApplicationNotes
Also can you please confirm that you are using the KW41Z-EVK board.
Hi Sr,
I found these functions below which seems helpful for sending data but don't know how to use them and how to initiate the communication.
ZPS_eAplAfApsdeDataReq
ZPS_eAplAfUnicastDataReq
ZPS_eAplAfUnicastIeeeDataReq
ZPS_eAplAfUnicastAckDataReq
ZPS_eAplAfUnicastIeeeAckDataReq
Please let me know how to use them and from where to call them for data transmission.
warm regards
Tushar
You can find some documentation that have the description of this functions and also explains how this should be used and how they work.
This information is located inside the SDK documentation inside the ZigBee 3.0 Stack User Guide. On the chapter 7.1.2 Data Transfer Functions you will find each function and how each one works.
Please let me know if there is anything else where I can help you.
Yes I found these functions in the documentation, but as we are running coordinator and router application they are command based only few commands are there regarding connection formation nothing about send data or receive data, please let me know how to implement data transmission.
Please find the following community post that I think can help you out, with the data transmission on the ZigBee with the KW41Z.
Please let me know if you found useful this information.
