hello,
I apologize but I can't provide the document directly through email, this should be downloaded by every customer due to the same confidentiality reasons, still , you can request the file directly.
Could you please help me enter the NXP web page and sign into your account ?
After being sure that you started your session could you please enter the part web page ?
Then you will go to the Design Resources section in the Documentation tab, after getting there , you should select the Secure Files option
Once you select that option , you should be able to see more files available there . Could you please help me confirm if you have some files available there ?
If you do not get to see any , there is a button for request higher access , could you please help me trying requesting higher access?
Also, for the power consumption, while we have some data related to the IC, if you are looking for the module consumption you should go with the module manufacturer . I apologize for the inconvenience this might cause you.
