UWB - MK UWB Mobile Edition Evaluation Kit
patsn
With this module, I understand that I can use an iPhone and its U1 chip.
I have some questions :
- Is the kit is compatible with an Samsung S21 Ultra phone which has an embedded UWB chip ?
- Can I add a NFC shield to the arduino equiped with the UWB Tag SR040 ? The purpose is to exchange data between the arduino through NFC protocol when the arduino is close to an mobile phone. Is this possible to do so ? My project is to open through a small distance (50cm) calculated by UWB a door equiped with a NFC reader. I approach the door (50cm) my phone send data through Bluetooth for example, and the reader take the data sent and then open the door.
Is it a feasible project ?
Ricardo_Zamora
Hope you are doing well. Could you please redirect your question to Mobile Knowledge?
They will be able to help you with the support of their kit.
Ricardo
