The problem of RAM and Shadow RAM in JN5169 chip
544 次查看
1948396491
Hello, I want to know the difference between RAM and Shadow RAM in JN5169 chip data.And how to use it?What is the approximate size of the stack by default?
481 次查看
mario_castaneda
The shadow RAM could help you to emulate a static RAM and the ability to retain data.
By default, the size is provided by the release note of each example that you are working on, you could see the memory usage.
Mario
