Hi!
My team has been using SR150-based UWB modules for more than a year now.
The development of our product is doing well but we would really need to scale our solution to more than 5 iPhones to range with one SR150.
Such threads seem to talk about having multiple ranging devices in one session. I cannot see how to apply this principle with the current state of UWB with smartphones.
After having tried to obtain the answer from module makers, I could not find someone able to explain me if I can have more than 5 sessions.
For example, we've seen documents about Multicast but could not figure out how to use it with phones.
Is any of this possible ?
Thank you very much.
Hope you are doing well. Are you using one the these Development Kits or Modules (UWB Developer Resources)?
If that is the case you would need to redirect your questions to the Module Maker, also it is good to go with them to know the process and the support that they can provide you.
I apologize for the inconveniences this might cause you.
Ricardo
