QN9080-001-M17-data type mismatch
1758793535
 HI.
Using uint8_ T to customize an array, which will result in data type mismatch and pointer offset beyond the bounds. How to modify this?串口流更新2+修改.png修改后警告.png
nxf56274
2D array is not necessary. 1D is enough. The usage of pointer has some problem. BTW, I have to say that this is the C language question, not the mcu question.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
1758793535
I've solved this C language problem, but this array can't be automatically sent to my mobile phone. Isn't this function used to send air data? Why can't my phone receive it?
nxf56274
The data you send is not the string or char. Try to initial a array that has the alphabet.
TIC
