KW36 - Can I use watchdog in low power mode?
jictannu
In MKW36A512RM, watchdog does not work in LLSx & VLLSx.
There are 8 DeepSleep mode in PWR_Configuration.h, looks like the watchdog only works in mode 6(MCU in STOP), But Mode 6 has a higher power consumption. Can I use watchdog in low power mode?
nxf56274
The code do not realize. You have to add code by yourself. Actually, I am not sure if it is good to add watchdog into the low power mode.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
nxf56274
If you choose 1khz source clock for watchdog, you can use watchdog in vlps mode.
TIC
jictannu
Hi nxf56274. How can I select vlps mode? In PWR_Configuration.h, no deepsleep mode is used in vlps mode.
 * The way that DeepSleep mode are handled. Following possibilities exist:
 *   1: MCU/Radio low power modes: This is a BLE DSM specific low power mode. It requires cPWR_BLE_LL_Enable TRUE.
 *        MCU in LLS3 mode.
 *        BLE_LL in DSM.
 *      Wakeup sources:
 *        GPIO (push button) interrupt using LLWU module(SW2(PTA18),SW3(PTA19)).
 *        BLE_LL wake up interrupt(BLE_LL reference clock reaches wake up instance register)  using LLWU module.
 *          - BTE_LL wakeup timeout: controlled by the BLE stack(SoC must be awake before next BLE action).
 *          - BTE_LL reference clock source:   32Khz oscillator
 *          - BTE_LL reference clock resolution:     625us
 *        LPTMR wakeup timeout: cPWR_DeepSleepDurationMs by default. Use PWR_SetDeepSleepTimeInMs
 *                                  to change it at run time. Maximum timeout is 65535000 ms (18.2 h).
 *          - LPTMR clock source:   32Khz oscillator
 *          - LPTMR resolution:     modified at run time to meet timeout value.
 *   2: MCU/Radio low power modes: This is a non DSM general purpose low power mode.
 *        MCU in LLS2 mode.
 *        BLE_LL must be idle or cPWR_BLE_LL_Enable FALSE.
 *        GEN_LL must be idle or cPWR_GENFSK_LL_Enable FALSE.
 *      Wakeup sources:
 *        DCDC PowerSwitch - available in buck mode only.
 *        LPTMR interrupt using LLWU module
 *          - LPTMR wakeup timeout: cPWR_DeepSleepDurationMs by default. Use PWR_SetDeepSleepTimeInMs
 *      RAM retention:
 *          - 16k Ram retention (0x20000000- 0x20003fff) if cPWR_RAM2_EnabledInLLS2 = 0(default)
 *          - 32k Ram retention (0x20000000- 0x20007fff) if cPWR_RAM2_EnabledInLLS2 = 1
 *   3: MCU/Radio low power modes: This is a non DSM general purpose low power mode.
 *        MCU in LLS3 mode.
 *      Wakeup sources:
 *   4: MCU/Radio low power modes: This is a non DSM general purpose low power mode.
 *        MCU in VLLS0/1 mode(VLLS0 if DCDC bypassed/ VLLS1 otherwise ).
 *      Wakeup sources:
 *   5: MCU/Radio low power modes: This is a non DSM general purpose low power mode.
 *        MCU in VLLS2 (16k Ram retention (0x20000000- 0x20003fff)).
 *      Wakeup sources:
 *   6: MCU/Radio low power modes:
 *        MCU in STOP.
 *      Wakeup sources:
 *        Any Radio interrupt
 *        UART
 *   7: MCU/Radio low power modes: This is a GENFSK DSM specific low power mode. It requires cPWR_GENFSK_LL_Enable TRUE.
 *        MCU in LLS3 mode.
 *        GENFSK_LL in DSM.
 *      Wakeup sources:
 *        GENFSK_LL wake up interrupt(GENFSK_LL reference clock reaches wake up instance register) using LLWU module.
 *          - GENFSK_LL reference clock source:   32Khz oscillator
 *          - GENFSK_LL reference clock resolution:     ~30.5us
 *   8: MCU/Radio low power modes: This is a BLE DSM specific low power mode. It requires cPWR_BLE_LL_Enable TRUE.
 *        MCU in VLLS2/3 mode.
 *        BLE_LL in DSM.
 *      Wakeup sources:
 *      RAM retention:
 *          - Full Ram retention in VLLS3
