Hi All
In the MKW2xDxxx reference manual (Rev. 1 Nov. 2013) the following is found:
In section 4.4.2
But
Therefore it looks like there is an error in the section 4.3.1.2 stating PTA18 rather than PTC0.
If a true error, it could be fed back to the documentation team for correction in a future edition.
Mark
Solved! Go to Solution.
Hello Mark,
It seems you are referring to an old revision of the Reference Manual. The current version available in our website states that PTC0 select the CLK_OUT frequency indeed. Please use this latest version for future reference.
Link: http://cache.freescale.com/files/rf_if/doc/ref_manual/MKW2xDxxxRM.pdf
AngelC
Hello Mark,
AngelC
