KW0x- Generating a continuous un-modulated signal
1,030件の閲覧回数
CesarM
Generating a Continuous Un-modulated signal is a common request for customers evaluating RF performance.
This allows the user to measure not only the accuracy of the transmission's center frequency but it is also useful
to measure power consumption.
To generate this signal the following steps are needed:
1) Set Data Mode to "Data Mode Continuous"
RegDataModul(0x02)
DATA MODE ->  Continuous mode (any: with or without bit syncrhonizer)
2) Set Fdev to zero
RegFdevMsb (0x05)= 0x00
RegFdevLsb (0x06)= 0x00
3) Put xcvr in TX mode
RegOpMode (0x01)
MODE -> 011 (Transmitter mode- TX)
Code Snippet example (SMAC-based):
    /*Set Data Mode*/
     PhyPib_SetDataMode(DataModul_DataMode_Continous);
     /*Set Fdev to zero*/
     PhyPib_SetFreqDeviation(0x00);
     /* Put transceiver in TX mode */
    PhyPib_SetOperationMode (OpMode_Transmitter);
0 返答(返信)
