I want to configure 88W8997 for WAPI on linux,but I don't know the method. Because I don't find the content about WAPI in the user‘s manual.
Would you tell me how do it ? Thank you.
I will use 88W8997's driver and formware as follow link:
driver:
https://github.com/marvell-wireless/mwlwifi-8997
firmware:
https://github.com/nxp-imx/imx-firmware/tree/lf-5.15.52_2.1.0/nxp/FwImage_8997
I don't know whether do this driver and firmware support WAPI ? Or does it still neet some other software for WAPI ?
Regards.
Hello @XiaoLong7626 ,
>>Is the chip 88W9098 or 88Q9098 which can support WAPI security kind ?
9098 means 88W9098 and 88Q9098. So they support WAPI.
>>does NXP have some user's manuals for configuring the security kind of WAPI ?
We have an application note for WAPI SUPPLICANT configuration.
it is on page of 88W8987, but usage is the same.
>>I don't know whether does the driver and firmware from github support WAPI ? Or does it still neet some other software for WAPI ?
The information (document & screenshot) I gave you in last reply is the driver on github. you can use L6.1.36 BSP branch, the driver and firmware version is decribed in that document, you can check it.
Actually, 8997 is WIFI 5, and 8987 is also WiFi 5. So you can also select 88W8987.
Thanks!
weidong
Hi, @weidong_sun
Thank you very much !
I'm sorry, but I don't find the pdf of WAPI wpa_supplicant in 88W8987 page. Would you send me the file ?
My email:xiaolong7626@163.com
Thank you !
Regards.
The document is security file, if you don't have access right to download it.
You can contact distributor or moudle makers , they can guide you how to do it.
Thanks!
weidong
Dear @XiaoLong7626 ,
See below, please!
1. checking release note document from the link if WAPI feature is supported by 88W8997
2. From the list below, 88W8997 doesn't support it
So please select correct WiFi chip for your application!
Thanks!
weidong
Hi,@weidong
Thank you for you reply!
By the way, does NXP have some user's manuals for configuring the security kind of WAPI ?
Looking forward your relpy, thank you!
Regards.
