How to change advertising duration between channel 37,38 and 39?
tedwu1
Hello friend,
I use a sniffer to monitor the BLE advertising time. The duration between channels 37, 38 and 39 is 1.5mS. Can I change the duration? If yes, how to change the advertising duration?
Thank you in advance.
Ted Wu
EduardoZamora
Hello @tedwu1
Hope you are doing well.
Just to confirm, what device are you using?
Eduardo.
tedwu1
Hi @EduardoZamora
I used MCU QN9021.
Thank you very much.
Ted Wu
EduardoZamora
I appreciate the information.
User is allowed to configure maximum time to remain advertising (timeout); and the minimum/maximum advertisement interval depending on a fast or slow advertisement (GAP_ADV_SLOW_MIN_INTV, GAP_ADV_SLOW_MAX_INTV).
Eduardo.
tedwu1
Hi @EduardoZamora
I think that  (GAP_ADV_SLOW_MIN_INTV, GAP_ADV_SLOW_MAX_INTV) configure the interval of advertising group of channel 37,38 and 39. But I want to change the duration between channel 37,38 and 39 at each advertising.
Ted Wu
EduardoZamora
This may be handled by the BLE stack. For more information, please consult Core Specification – Bluetooth® Technology Website.
Eduardo.
