Energy scan Zigbee 3.0 FRDM-KW41Z
1,480 次查看
BasWep
Can anyone tell me how to execute an energy scan, and select the best zigbee channel.
Kind regards,
Bas
9 回复数
1,465 次查看
EduardoZamora
Hello @BasWep
Hope you are doing well.
Could you please provide more details about your requirements? Are you looking for a way to change the channel on an already initialized network?
In the process of Network Creation, when Co-ordinator starts a network and after EPID is set, Co-ordinator selects the radio channel within the chosen RF band by performing an Energy Detection, but this event should be done by the stack. For more information on this, could you please take a look at the ZigBee 3.0 Stack User Guide (inside KW41Z SDK > docs > wireless > Zigbee)?
Eduardo.
1,457 次查看
BasWep
Hello Eduardo,
Thank you for your fast response.
Yes we use that doc. but I can’t in the code the function that execute the energy scan and selected the best channel. Can you tell me were I can find it?
Kind regards,
Bas
1,429 次查看
EduardoZamora
I apologize for the delay.
Could you please confirm if function ZPS_eAplZdpMgmtNwkUpdateRequest() is useful for your application? This function requests an update of network parameters related to radio communication.
Also, structure ZPS_tsAplZdpMgmtNwkUpdateNotify stores Mgmt_NWK_Update_notify data - a notification which can be sent in response to a call to the function ZPS_eAplZdpMgmtNwkUpdateRequest(). This notification reports the results of an energy scan on the wireless network radio channels.
For more information on this, please take a look at the ZigBee 3.0 Stack User Guide.
Eduardo.
1,383 次查看
BasWep
Hello Eduardo,
Thank you for the info!
Were are busy and testing the function: ZPS_eAplZdpMgmtNwkUpdateRequest()"
But we can’t find info and need the more info about following thinks:
ZPS_EVENT_NWK_ROUTE_RECORD_INDICATION
ZPS_eAplZdpMgmtNwkEnhanceUpdateRequest
ZPS_eAplZdpMgmtUnsolicitedEnhancedUpdateNotify
zps_eZdpMgmtNwkUpdateNotifyResponse
ZPS_teAfEventType  more info/description over eventtypes
In ZPS_eAplZdpMgmtNwkUpdateRequest: "update the radio channel mask (for scans) and the 16-bit network address of the network manager (node nominated to manage radio-band operation of network) ";
How works the "network manager"? And does it work on offline nodes or nodes with a reset?
Can you help us or is it possible to contact someone directly of NXP
Kind regards,
Bas
1,325 次查看
EduardoZamora
Could you please help us with more details about what are you trying to achieve with these APIs? What is the purpose of their implementation in your development?
Eduardo.
1,316 次查看
BasWep
Hello Eduardo,
We are testing a mesh network and we are thing that only when a new node initials starts a network discovery will be performed.
There is no documentation about the functions I asked.
Kind regards
Bas
1,302 次查看
EduardoZamora
Could you please confirm if any of the Zigbee example projects from the KW41Z SDK meets your requirements? These functions may not be implemented (and may not be relevant/useful) in the example projects. The available documentation can be found inside KW41Z docs folder > docs > wireless > Zigbee.
Also, you can take a look at the Zigbee Application Notes inside KW41Z SDK folder > docs > wireless > Zigbee > Application Notes.
Eduardo.
1,288 次查看
BasWep
Hello Eduardo,
Yes we have search in the docs, please provide better information or help we with contact someone from NXP.
Kind regards,
Bas
1,272 次查看
EduardoZamora
  • ZPS_EVENT_NWK_ROUTE_RECORD_INDICATION
    Indicates when a route record is received. Each route record should contain the destination network address, a count of the number of relay nodes to reach the destination, and a list of the network addresses of the relay nodes.
  • ZPS_teAfEventType
    More information on this can be found in Zigbee 3.0 Stack User Guide, Chapter 10.1 Events, and Table 21.
  • Network Manager
    Please, refer to ZigBee Specification for more information on this.
The rest of the APIs may not be relevant/useful or are only for internal usage. I apologize for insisting, please take a look at the Zigbee examples from the SDK and the Application Notes, here you can find an implementation of the functionalities that you are looking for.
Eduardo.
