hi ,
I have a custom Vybrid VF6 board ,nand is 2k+64page 8bit width(MT29F8g08abaeh4)
I am using u-boot 2013 .07 from timesys , I downloaded the u-boot image successfully using MFG tool ,
yet it just can not boot ,it jumps to serial download after reset.
the value of SRC_SBMR2 is 0x8000011,
SRC_SBMR1:0x1280
so bootmode is set correctly.
the attachment is the FCB data and IVT i nand dumped, I cannot see anything wrong with it. it's weird
Original Attachment has been moved to: dump-data.txt.zip
Solved! Go to Solution.
hi,
I have solve the problem, though i don't know why.
it seems that there is something wrong with the Factory i downloaded from timesys .
after i re make it ,and rebuild u-boot, it works well
thanks
timesyssupport can you help with this case?
hi,
thanks
