The downloader requires a "version 3" header. The open source version of u-boot does not support this header type. We added the type which affected imximage.cfg, tools/imximage.c, and tools/imximage.h. This resolved the "HAB" error.
Are you using MfgTool to flash this u-boot on SD, NAND, QSPI??
When do you see those messages, when flashing, when trying to boot?
Can you share the u-boot binary you are trying to flash to try it at my end?
