I2C Clock Stretching in Vybrid
srebbago
Hi ,
I want to know how to enable I2C clock stretching in Vybrid F-series. In reference manual(VYBRIDRM.pdf), I have found the below data(snap shot). But, didn't get information about which register/pin will set clock stretching. or Is clock stretching is enabled default in Vybrid?.
Give me clarification on this ASAP.
Labels (3)
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
CommunityBot
Community Manager
NXP Community!
jiri-b36968
Hello Siva,
clock stretching is a feature of I2C itself. It is always enabled. Any slave can slow down data transfer controlled by the master by holding CLK low for necessary time after the master sets CLK low. The master will continue with transfer once CLK is released.
/Jiri
