Hi community.
Our customer want to use SSC function of PLL1 and PLL2 .Becouse There are noise issues.
I read Vybrid RM of sect 9.4.2 Spred Spectrum but i could not be well understood. .
Do I get the recommended value to be set to specifically PLL1 and PLL2.
Frequency, width, step does not matter in the recommended settings.
Solved! Go to Solution.
There is a document for iMX6 devices. enable the spread spectrum
The clocking of both devices are similar and I think it can help.
Are you trying to achieve an specific modulation frequency and depth?
Alejandro
Alejandro
