Binary Loading : TCM and OCRAM
1,282 次查看
carlovalgocela
Hello
In Vybrid Architecture manual, a TCM backdoor is intended to load the code and data into TCM by Cortex-A5 (primary core) prior to running Cortex-M4 (secondary core).
It actual it is loaded in the OCRAM-SysRAM0.  Can anybody explain why it is loaded in SysRAM0 and not in the TCM?
标签 (3)
标记 (3)
899 次查看
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
900 次查看
CommunityBot
Community Manager
NXP Community!
902 次查看
jiri-b36968
Hello Carlo,
missing some information like which code or data, what project...
Anyway, generally the placement of the code and data depends on Linker command file (IAR) - see supp.iar.com or scatter file  (DS5) - see Loading this site
Depending on your IDE you can select location of your code and date and build the project with this setting. Then your code will be placed where you want.
/Jiri
