bitbake fsl-toolchain error
sandeepk1980
I am trying to build fsl-toolchain using SDK2.0 on Ubuntu 16.04. . I am able to build fsl-image-core but when i try to build bitbake fsl-toolchain , i am getting this error
WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Parsing recipes: 100% |###############################################################################| Time: 00:01:07
Parsing of 2705 .bb files complete (0 cached, 2705 parsed). 6101 targets, 695 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
/home/cdot/brtr_old_103/brtr/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/dynamic-layers/openstack-layer/recipes-connectivity/openssh/openssh_7.1p1.bbappend
/home/cdot/brtr_old_103/brtr/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-cgl/meta-cgl-common/recipes-extended/openipmi/openipmi_2.0.21.bbappend
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version 2.7.9 of python not available (for item python)
NOTE: versions of python available: 2.7.18
NOTE: preferred version 2.7.9 of python not available (for item python-shell)
NOTE: preferred version 2.7.9 of python not available (for item python-io)
NOTE: preferred version 2.7.9 of python not available (for item python-math)
NOTE: preferred version 2.7.9 of python not available (for item python-crypt)
NOTE: preferred version 2.7.9 of python not available (for item python-logging)
NOTE: preferred version 2.7.9 of python not available (for item python-fcntl)
NOTE: preferred version 2.7.9 of python not available (for item python-subprocess)
NOTE: preferred version 2.7.9 of python not available (for item python-pickle)
NOTE: preferred version 2.7.9 of python not available (for item python-compression)
NOTE: preferred version 2.7.9 of python not available (for item python-textutils)
NOTE: preferred version 2.7.9 of python not available (for item python-stringold)
NOTE: preferred version 2.7.9 of python not available (for item python-2to3)
NOTE: preferred version 2.7.9 of python not available (for item python-argparse)
NOTE: preferred version 2.7.9 of python not available (for item python-audio)
NOTE: preferred version 2.7.9 of python not available (for item python-bsddb)
NOTE: preferred version 2.7.9 of python not available (for item python-codecs)
NOTE: preferred version 2.7.9 of python not available (for item python-compile)
NOTE: preferred version 2.7.9 of python not available (for item python-compiler)
NOTE: preferred version 2.7.9 of python not available (for item python-contextlib)
NOTE: preferred version 2.7.9 of python not available (for item python-core)
NOTE: preferred version 2.7.9 of python not available (for item python-ctypes)
NOTE: preferred version 2.7.9 of python not available (for item python-curses)
NOTE: preferred version 2.7.9 of python not available (for item python-datetime)
NOTE: preferred version 2.7.9 of python not available (for item python-db)
NOTE: preferred version 2.7.9 of python not available (for item python-debugger)
NOTE: preferred version 2.7.9 of python not available (for item python-difflib)
NOTE: preferred version 2.7.9 of python not available (for item python-distutils)
NOTE: preferred version 2.7.9 of python not available (for item python-doctest)
NOTE: preferred version 2.7.9 of python not available (for item python-elementtree)
NOTE: preferred version 2.7.9 of python not available (for item python-email)
NOTE: preferred version 2.7.9 of python not available (for item python-gdbm)
NOTE: preferred version 2.7.9 of python not available (for item python-hotshot)
NOTE: preferred version 2.7.9 of python not available (for item python-html)
NOTE: preferred version 2.7.9 of python not available (for item python-idle)
NOTE: preferred version 2.7.9 of python not available (for item python-image)
NOTE: preferred version 2.7.9 of python not available (for item python-importlib)
NOTE: preferred version 2.7.9 of python not available (for item python-json)
NOTE: preferred version 2.7.9 of python not available (for item python-lang)
NOTE: preferred version 2.7.9 of python not available (for item python-mailbox)
NOTE: preferred version 2.7.9 of python not available (for item python-mime)
NOTE: preferred version 2.7.9 of python not available (for item python-mmap)
NOTE: preferred version 2.7.9 of python not available (for item python-multiprocessing)
NOTE: preferred version 2.7.9 of python not available (for item python-netclient)
NOTE: preferred version 2.7.9 of python not available (for item python-netserver)
NOTE: preferred version 2.7.9 of python not available (for item python-numbers)
NOTE: preferred version 2.7.9 of python not available (for item python-pkgutil)
NOTE: preferred version 2.7.9 of python not available (for item python-pprint)
NOTE: preferred version 2.7.9 of python not available (for item python-profile)
NOTE: preferred version 2.7.9 of python not available (for item python-pydoc)
NOTE: preferred version 2.7.9 of python not available (for item python-re)
NOTE: preferred version 2.7.9 of python not available (for item python-readline)
NOTE: preferred version 2.7.9 of python not available (for item python-resource)
NOTE: preferred version 2.7.9 of python not available (for item python-robotparser)
NOTE: preferred version 2.7.9 of python not available (for item python-smtpd)
NOTE: preferred version 2.7.9 of python not available (for item python-sqlite3)
NOTE: preferred version 2.7.9 of python not available (for item python-sqlite3-tests)
NOTE: preferred version 2.7.9 of python not available (for item python-syslog)
NOTE: preferred version 2.7.9 of python not available (for item python-terminal)
NOTE: preferred version 2.7.9 of python not available (for item python-tests)
NOTE: preferred version 2.7.9 of python not available (for item python-threading)
NOTE: preferred version 2.7.9 of python not available (for item python-tkinter)
NOTE: preferred version 2.7.9 of python not available (for item python-unittest)
NOTE: preferred version 2.7.9 of python not available (for item python-unixadmin)
NOTE: preferred version 2.7.9 of python not available (for item python-xml)
NOTE: preferred version 2.7.9 of python not available (for item python-xmlrpc)
NOTE: preferred version 2.7.9 of python not available (for item python-zlib)
NOTE: preferred version 2.7.9 of python not available (for item python-misc)
Build Configuration:
BB_VERSION = "1.28.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-16.04"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "t1040d4rdb-64b"
DISTRO = "fsl-qoriq"
DISTRO_VERSION = "2.0"
TUNE_FEATURES = "m64 fpu-hard e5500"
TARGET_FPU = "hard"
meta = "HEAD:9a211a4a2c1bfcb292dc97d8dcac149bca9e3f1b"
meta-cgl-common = "HEAD:a8a7d8112ac8eb02c5752780dad001ce322291b2"
meta-yocto
meta-yocto-bsp = "HEAD:9a211a4a2c1bfcb292dc97d8dcac149bca9e3f1b"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-xfce = "HEAD:dc5634968b270dde250690609f0015f881db81f2"
meta-freescale = "HEAD:7facbdb726e2dda0515e084c2066a4b8dd99c6d2"
meta-freescale-internal = "HEAD:4829293f807e35a1111e79763294fc8b98b97810"
meta-freescale-extra = "HEAD:bee911b027e0480b034674d0ddee3fcb06d2e985"
meta-virtualization = "HEAD:042425c1d98bdd7e44a62789bd03b375045266f5"
meta-java = "HEAD:8b776ac68f9af4596be3824152bcf0bc6b67fa1d"
meta-openstack
meta-openstack-aio-deploy
meta-openstack-compute-deploy
meta-openstack-compute-test-config
meta-openstack-controller-deploy
meta-openstack-controller-test-config
meta-openstack-qemu
meta-openstack-swift-deploy
meta-cloud-services = "HEAD:d8bc0d92d0f741e2ea1e6d3d9bc6b7a091d03cfb"
meta-security = "HEAD:f9367e71f923fc7d2fb600208e2b97535ea41777"
NOTE: Preparing RunQueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Unable to install packages. Command '/home/cdot/brtr_old_103/brtr/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/smart --log-level=warning --data-dir=/home/cdot/brtr_old_103/brtr/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/fsl-toolchain/1.0-r7/sdk/image/opt/fsl-qoriq/2.0/sysroots/ppc64e5500-fsl-linux/var/lib/smart install --attempt -y bash-dbg@ppc64e5500 gcc-runtime-dbg@ppc64e5500 glibc-locale-dbg@ppc64e5500 ncurses-dbg@ppc64e5500 dtc-dbg@ppc64e5500 libglib-2.0-dbg@ppc64e5500 libffi-dbg@ppc64e5500 libz-dbg@ppc64e5500 opkg-utils-dbg@ppc64e5500 opkg-utils-dev@ppc64e5500 base-files-dbg@t1040d4rdb_64b packagegroup-core-standalone-sdk-target-dev@all' returned 1:
Loading cache...
Updating cache... ######################################## [100%]
Computing transaction...warning: Can't install opkg-utils-dev-0.1.8+git0+53274f0875-r0@ppc64e5500: Can't install opkg-utils-0.1.8+git0+53274f0875-r0@ppc64e5500: no package provides python-logging
error: opkg-utils-0.1.8+git0+53274f0875-r0 requires python-pickle
error: opkg-utils-0.1.8+git0+53274f0875-r0 requires python-shell
error: opkg-utils-0.1.8+git0+53274f0875-r0 requires python-subprocess
error: opkg-utils-0.1.8+git0+53274f0875-r0 requires python-logging
error: opkg-utils-0.1.8+git0+53274f0875-r0 requires python-compression
error: opkg-utils-0.1.8+git0+53274f0875-r0 requires python-fcntl
Installing packages (29):
base-files-dbg-3.0.14-r89@t1040d4rdb_64b
bash-dbg-4.3.30-r0@ppc64e5500
cryptodev-qoriq-module-1.8-r0@t1040d4rdb_64b
dtc-dbg-1.4.1+git0+302fca9f4c-r0@ppc64e5500
gcc-runtime-dbg-4.9.2-r0@ppc64e5500
glibc-locale-dbg-2.22-r0@ppc64e5500
kernel-4.1.8-rt8+gbd51baf-4.1-r0@t1040d4rdb_64b
kernel-module-cryptodev-1.8-r0@t1040d4rdb_64b
libcrypto1.0.0-1.0.2h-r0@ppc64e5500
libffi-dbg-3.2.1-r0@ppc64e5500
libglib-2.0-dbg-1:2.44.1-r0@ppc64e5500
libpython2.7-1.0-2.7.18-r1@ppc64e5500
libreadline6-6.3-r0@ppc64e5500
libssl1.0.0-1.0.2h-r0@ppc64e5500
libz-dbg-1.2.8-r0@ppc64e5500
ncurses-dbg-5.9-r15.1@ppc64e5500
openssl-qoriq-1.0.2h-r0@ppc64e5500
openssl-qoriq-conf-1.0.2h-r0@ppc64e5500
opkg-utils-dbg-0.1.8+git0+53274f0875-r0@ppc64e5500
packagegroup-core-standalone-sdk-target-dev-1.0-r8@all
python-core-2.7.18-r1@ppc64e5500
python-crypt-2.7.18-r1@ppc64e5500
python-io-2.7.18-r1@ppc64e5500
python-lang-2.7.18-r1@ppc64e5500
python-math-2.7.18-r1@ppc64e5500
python-readline-2.7.18-r1@ppc64e5500
python-stringold-2.7.18-r1@ppc64e5500
python-textutils-2.7.18-r1@ppc64e5500
17.3MB of package files are needed. 69.8MB will be used.
Saving cache...
ERROR: Function failed: do_populate_sdk
ERROR: Logfile of failure stored in: /home/cdot/brtr_old_103/brtr/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/fsl-toolchain/1.0-r7/temp/log.do_populate_sdk.9533
ERROR: Task 7 (/home/cdot/brtr_old_103/brtr/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-fsl/images/fsl-toolchain.bb, do_populate_sdk) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2291 tasks of which 2290 didn't need to be rerun and 1 failed.
No currently running tasks (2290 of 2292)
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
please provide the solution
