I have a design layout using a T1024 processor. The design uses JTAG/COP for debug/programming. For the JTAG/COP do I need to connect the JTAG/COP to the processor HRESET_B, or can I leave HRESET_B as not-connected?
The T1 series migration guide (AN5079) says reset assertion should only use PORESET_B, and there is no soft reset. This seems to suggest the processor HRESET_B should not be connected.
The CodeWarrior TAP manual (CWTAPUG) section 9 says COP SRST_B (pin11) 'may' be connected. Does this say pin11 is optional? Will the emulator work correctly if COP SRST_B is not connected?
Kind regards,
Paul
Solved! Go to Solution.
That's the same diagram as in the T1024 datasheet (chapter 4.5). I've been using this as a reference. What I wanted to know is what the minimum connections are required to support the COP. I have a working board now and have determined that:
HRESET_B must be pulled-up to OVDD (via a 1K resister).
System board reset (from FPGA/CPLD) must be connected to PORESET_B and TRST_B.
COP_HRESET_B must be connected to PORESET_B.
COP_SRESET_B not-connected.
COP_TRST_B must be connected to TRST_B.
The above arrangement works ok. My original question was about HRESET_B, which I discovered must be either connected to logic or pulled-up. I also discovered the CodeWarrior TAP emulator does not appear to use COP_SRESET_B so can be left not-connected.
Thanks again.
Please find in the QorIQ T1024 Family Design Checklist - Chapter 5.21.2 JTAG system-level recommendations:
Correct operation of the JTAG interface requires configuration of a group of system control pins as demonstrated in Figure 23. Care must be taken to ensure that these pins are maintained at a valid deasserted state under normal operating conditions,
as most have asynchronous behavior and spurious assertion gives unpredictable results.
Thanks again.
