We are now using serdes tool to configure the serdes of T4240, encounter some issues,
Could you please help to give some suggestions?
As the below figure shows, there are so many strange parameters to set, so my questions
is that how should I use the tool to configure these parameters?
Since these parameters are complex and strange, if I should configure it manually, it really
a horrible thing, Can the serdes tool automatically choose a suitable value for these parameters ?
Thank you!
You should use Read from target option if you want to have the options populated for each lane.
Adrian
