How to use the SFP+ ports at 1G?
次の代わりに検索
484件の閲覧回数
helloppc
As per question, I am using the T4240RDB and, for compatibility, I would like to use the SFP+ ports at 1G instead of 10G.
Following the fman specs, I added the property fsl,fman-best-effort-port in the dtb, but my switch can't establish the connection (Dell 5324): I tried with auto-negotiation enabled and disabled.
Should I change anything else? Or am I misunderstanding the specs of FMAN?
タグ(3)
411件の閲覧回数
bpe
Line data rate has nothing to do with any FMAN Device Tree properties because it is selected in another module, SerDes.
SerDes mode used for connecting to  SFP+ interfaces is XFI, which is a single data rate protocol. It will not autonegotiate
and switch to 1G. You have to perform  a full reset with another RCW to switch the SerDes lane to SGMII/1000Base-KX.
Platon
