How to compile uio_seville driver in sdk 3.1 for T1040RDB
Suraj_Prakash
      I have been working on T1040RDB and the SDK which i have been using is 3.1.
I want to uio_seville driver which works on internal L2 switch of T1040 processor.
Can you please suggest how to compile the driver in SDK 3.1?
yipingwang
I compiled your uio-seville source code in Yocto SDK 3.1 build environment, I encountered the attached compilation errors.
Please check your uio-seville source code again.
Suraj_Prakash
HI,
     I was able to compile and run the seville driver. Thanks a lot for the help
Suraj_Prakash
sure. Please find attached the patch
Suraj_Prakash
Also please find attached my dts /dtsi files patch
yipingwang
After recompiling Linux Kernel, have you also recompiled uio_seville module at the same time.
Suraj_Prakash
yeah did that...even though getting the error
Suraj_Prakash
adding to the latest query
    I am using rootfile system from SDK 2.0 and linux & uio_seville driver from SDK 3.1
