Error when compiling ROM elf file
872件の閲覧回数
stevenstarnes
   I am trying to compile the ROM file to flash onto my T2080 board. However whenever I try to compile the rom source I get the error "relocation truncated to fit: R_PPC64_ADDR16_HI against symbol `ddrclk_opts' defined in .init_data section in ./Sources/T2080QDS_init.o". I am using the T2080QDS bare board project as a starting point and adding my own code as needed. As far as I can tell it appears I have ran out of room maybe? Any help on trying to figure out this problem would be appreciated. Thanks!
3 返答(返信)
769件の閲覧回数
Pavel
Is there similar error message if your code is not used in the T2080QDS bare board project?
Is your code try to access or change the "ddrclk_opts"?
Pavel Chubakov
769件の閲覧回数
stevenstarnes
I solved the issue. In the default board setup fir T2080QDS_init.c there is assembly code written as: asm("lis 4, ddrclk_opts@h") this should be changed to asm("lis 4, ddrclk_opts@high"). I believe that @high is for 64 bit builds
769件の閲覧回数
stevenstarnes
If I just compile the bareboard project without modifying anything it compiles without errors.
No my code doesn't modify any the ddrclk_opts variable. When I remove the section regarding the DDR clock it works just fine. The board I am working with does not contain a QIXIS i believe so it is irrelevant to my project anyways.
