Determining T1042 timebase frequency
Search instead for
nakrachi
Hi Everyone,
We are trying to determine the right frequency at which the timebase is updated.
According to the reference manual the core timebase frequency is calculated as follows :
Timebase clock = (platform_clock/16) / TBCLKDIVR
in our case :
  • Platform clock is 600 Mhz
  • RCPM_PCTBCKSELR is 0 -> Core Timebase is clocked with Platform Clock /16
  • TBCLKDIVR is 0x2 -> 1/8
so our timebase frequency should be : 600/(16*8) = 4.6875 Mhz
but when measuring with the logic analyzer we get a timebase frequency of 50Mhz.
I would like to confirm if I a calculated the right frequency or if I missed something,
thank you
nakrachi
The only pin available to me was the UART_SOUT which I had to configure as GPIO1[15] by modifying the RCW.
I used the debugger RCW override function to use my new RCW, I figured out that the debugger will set the platform PLL to 4:1 even though my RCW is setting it to be 6:1. meaning that my platform clock is 400 Mhz and not 600 Mhz (SYSCLK is 100Mhz).
which make a little bit more sense, if we consider that platform clock is only divided by TBCLKDIVR, 400Mhz/8 = 50 Mhz
 I think that "RCPM_PCTBCKSELR is 0 -> Core Timebase is clocked with Platform Clock /16" statement is not true.
Can you please confirm.
thank you
ufedor
How exactly you did that?
nakrachi
Thanks for the reply,
I did set the decrementer to a value of 50000 ticks
with Auto reload enabled (TCR= 0x0000000000400000)
then in the decrementer exception vector (IVOR10) I toggle a GPIO which I measure with the logic analyzer.
I get a frequency of 1Khz (a period of 1 ms)
which makes me believe I am running at 50 Mhz (50000 * 1Khz)
ufedor
DECAR in your case is zero.
nakrachi
The debugger can't read it (according to core manual "The DECAR contents cannot be read")
but I know that I wrote the right value and I am getting decremented exceptions at a fixed interval.
ufedor
Please show using Trace32 values of:
RCPM_PCTBCKSELR
RCPM_TBCLKDIVR
nakrachi
Here is a screenshot
ufedor
What is SYSCLK frequency?
Please provide U-Boot booting log.
nakrachi
The system frequency is 100MHz
here is the u-boot log
ufedor
600/50=12
I have no idea how such ratio can be obtained.
ufedor
Please combine all consistent experimental data into single Word or PDF document.
nakrachi
just making sure, you want me to describe the issue with relevant data/screenshots and post it here ?
thanks
ufedor
Yes, please.
nakrachi
@ufedor please fin attached the requested document.
nakrachi
Hi @ufedor , just following up on this.
thanks
ufedor
Your understanding is correct.
Time base frequency = (Platform clock )/RCPM_TBCLKDIVR When RCPM_PCTBCKSELR [PCTBCKSELn] = 0, Core Timebase is clocked with Platform Clock/ RCPM_TBCLKDIVR [tbclkdiv].
It is recommended to have the default value of RCPM_TBCLKDIVR [tbclkdiv], i.e., 0x00 : 1/16. This field should not be modified by customer as all the testing are done with Timebase clock divider configuration = 1/16.
Comment is added in T1042RM.
nakrachi
Thank you,
But then we have another problem, the erratum A-010651 states that the workaround is changing the RCPM_TBCLKDIVR [tbclkdiv], to 0x08 : 1/32.
but you mentioned we should not change it. how can we workaround this errata then ?
thanks
nakrachi
Thanks for the quick replies,
as I mentioned in an earlier comment, I found out that using the temporary RCW has set my PLL ration to 4:1 so I was running at 400Mhz when I got 50Mhz.
Now after setting back the platform clock to 600Mhz  I measure a time base frequency of 75Mhz. (600/8)
which makes me believe that the user manual is wrong
