Deployment of kernel versions greater than SDK 2.0 for T4240RDB
搜索替代
416 次查看
sedat_altun
I need to deploy linux kernel version 4.9 or 4.14 for T4240RDB.
Since the latest official kernel version is 4.1.35  published by NXP  from SDK 2.0 , I got the kernels for version gretater than 4.1.35  from nxp qoriq git repo
GitHub - qoriq-open-source/linux
I tried 4.9 and 4.14 versions for T4240RDB but I could not succeed to enable the ethernet interfaces.
I followed the following steps:
1 - make corenet64_smp_defconfig
2 - make fsl/t4240rdb.dtb
3 - I am using the file system from SDK 2.0
Then I boot the board with new kernel and dtb images, there is no any problem during boot but there is no ethernet interfaces.
Is this a valid way to get kernel versions greater than SDK 2.0 for T4240rdb board ?
Any help is appreciated.
标记 (2)
266 次查看
Pavel
See the following link for new Yocto BSP for QorIQ PowerPC:
https://source.codeaurora.org/external/qoriq/qoriq-components/yocto-sdk/about/
This SDK provides Linux kernel 4.14 and support the t4240rdb-64b
Pavel Chubakov
267 次查看
Pavel
Pavel Chubakov
