Programming without license
搜索替代
1,694 次查看
rdazcal
Greetings,
I have developed a firmware for a CF-V2 on the CW7.2 platform and intend to develop a second one.
But on this second one, it was requested that the support team need to be able to re-program the devices on field if a FW update is required.
Since my code exceeds Freescale's free license limitation, I have bought a floating license to use here in the company.
But on the field that will not be a possibility.
It seems my only option is to provide the support team with a Cyclone MAX stand alone programmer, but that means $900 per support team, which is a LOT.
Isn't there any other option for me? What about CW10? Does it have a higher size limitation than CW7.2 for the CF-V2 family?
Thank you
1,344 次查看
mjbcswitzerland
Specialist V
CFFlasher is a good option together with P&E BDM. It will not disturb any other programs.
The uTasker project includes boot loaders for the CF V2 parts - USB, serial and Ethernet, depending on what the parts has, included encrypted loading support for working with chips with protected FLASH settings. See www.uTasker.com
Mark
7 回复数
1,344 次查看
scifi
Senior Contributor I
1,344 次查看
rdazcal
Thanks scifi...
How safe is it to install CF Flasher?
Can it affect my current CW7.2 functionality?
1,344 次查看
scifi
To be honest, I don't know. In theory, it shouldn't. Obviously, if you try to use the BDM adapter simultaneously with CW and CF Flasher, some kind of conflict may occur.
1,345 次查看
mjbcswitzerland
Specialist V
Mark
1,344 次查看
TomE
Specialist II
Can you change the device to program itself from Ethernet, USB or a serial port?
1,344 次查看
rdazcal
Hi Tom,
Making it program it self will be quite tricky... although it's definetly a goal for the near future.
Do you know if there is code size limitation in CW10 for programming on the free license?
1,344 次查看
J2MEJediMaster
Specialist I
Size limit for the Special Edition of CW v10 for MCUs, in regard to ColdFire V2 programs, is 128KB.
---Tom
