what's the mearsurement range of Acc sensor SX2531KVWT?and does it a PSI5 output sensor?
bruce_Lee
I'm designing a crash acceleration sensor and find the chip SX2531KVWT.
but i counldn't find the datasheet on NXP website and internet.
i just want to know the SX2531 measurement range and output format then choose a mordern P/N to use.
Thanks!
diazmarin09
Hello Bruce,
I hope all is great with you.
I am afraid that such documentation is confidential. In this case, you may share your NDA number.
Have you considered the device below?
FXLS8974CF - ±2g/±4g/±8g/±16g, Low-Power 12-Bit Digital IoT Accelerometer
FXLS8974CF is a compact 3-axis MEMS accelerometer designed for use in a wide range of industrial and medical IOT applications that require ultra-low-power wake-up on motion. The part supports both high-performance and low power operating modes, allowing maximum flexibility to meet the resolution and power needs for various unique use cases.
David
