What are the defined values for a MMA8451 0x0D: WHO_AM_I Device ID register?
758件の閲覧回数
johnl_males
According to the MMA8451"Data sheet: Technical data", Document Number: MMA8451Q, Rev. 10.1, 05/2016, bottom of page 26:
"The device identification register identifies the part. The default value is 0x1A. This value is factory programmed. Consult the factory for custom alternate values."
Are there "custom alternate values" for the MMA8481?  If so what are they and their meaning?
2 返答(返信)
496件の閲覧回数
reyes
The factory programed value for register 0x0D “WHO_AM_I” is the same for all the MMA8451 accelerometers, if you read this register it should always be 0x1A.
This read only register only works only as an identification registers, so I do not see the need to use an alternate value for this register, but if needed, you need to consult it with the factory by contacting your NXP sales representative directly.
Jose
496件の閲覧回数
johnl_males
Hello Jose,
Thanks for your reply.
My question was to confirm and if the MMA8451 read only device identification register is known to have a value other than 0x1a" . The question was if, if so what values existed, and their meaning?  I did not wish to have a different value.
John
