Cannot find firmware for RD-KL25-AGMP01
arashfotouhi
I got the board and everything was working fine with the default firmware but I played around with the board a little bit and now I don't see the green flashing light. Where do I find the default firmware? How do I reset the board to the original state?
TomasVaverka
Hi Arash,
Please try to use the binary file that is located in the Freedom Sensor Toolbox (CE) installation folder:
C:\Program Files (x86)\NXP\Freedom Sensor Toolbox (CE)\Projects\GENERIC-DATA-LOGGER\Firmwares\ISSDK\RD-KL25-AGMP01_OnBoard_GDL_2.0.bin
If you need instructions to program the board, please refer to Chapter 3.4 of the RDKL25AGMP01UG.
Hope it helps.
Tomas
