SE050 RSA Performance
2,687 次查看
klaus_mueller
i am working with SE050 Arduino kit connected to Raspberry Pi. In my setup the ECC sign and verify commands are very fast. But if I use RSA 2k keys, I experience in my setup roughly 4 seconds for RSA sign and roughly 4 seconds for RSA verify. Is this an expected performance range or might there be an issue on my side?
6 回复数
2,291 次查看
klaus_mueller
one short adder to my previous description. I have realized that RSA verify takes in majority cases roughly 4s, but in few cases (e.g. previous log) much less e.g. 760ms..
Thanks.
2,291 次查看
Kan_Li
Thanks for the information! I will try it on my side.
BTW, I didn't see and time measurement info from the log, so how did you measure the time? Please kindly clarify.
Thanks for your patience!
Kan
2,291 次查看
klaus_mueller
within above log RSA sign was 4282ms and verify was 761ms. Please look for the line starting with msec time
RSA sign is very stable in the area of 4282. The RSA verify is either 761ms (in roughly 1/4 cases) or roughly 4000ms (in roughly 3/4 cases).
Please see how I measured:
I have patched the file ex_sss_rsa.c in function ex_sss_entry(…).
On top of the file I have included time.h. I get the time (in ns) before and after the function call
To “sss_asymmetric_sign_digest”. I calculate the time difference and print it.
#include <time.h>
Long int start_time;
Long int time_difference;
Struct timespec gettime_now;
   clock_gettime(CLOCK_REALTIME, &gettime_now);
    start_time = gettime_now.tv_nsec;
    status = sss_asymmetric_sign_digest(&ctx_asymm, digest, digestLen, signature, &signatureLen);
    time_difference = gettime_now.tv_nsec - start_time;
    printf("nsec time is %lu\n", time_difference);
    printf("msec time is %f\n", (float)(((unsigned long int)time_difference)/1000000));
2,291 次查看
Kan_Li
Hi Klaus Mueller,
I think the method you used for measure the timing is correct, but it also take other parts into calculation, for example, since you run the application in the linux, there were multiple tasks run at the same time, so the context switching also consume some time, so I think better measure based on a nonOS situation, you know, we have also released SE050 FRDMK64 version hostlib, based on that you may get the correct RSA performance. Please refer to https://www.nxp.com/webapp/Download?colCode=SDK-FRDM-K64F-SE050 for details.
I use the LPTMR to measure the time and the result is as below:
Please note this result still take the I2C communication into calculation, so the real rsa performance should be shorter.
Kan
2,291 次查看
klaus_mueller
Hi Kan,
I have been using the middleware package called  se050_mw_v02.10.02.zip ( md5sum: b713c482eb52a795061ba1b747044b07).
I included the example called "ex_sss_ecc.c" and "ex_sss_rsa.c" into the build ending up with the binaries called ex_ecc and ex_rsa which I can call from my shell on raspberry pi.
When measuring the execution time of the call "sss_asymetric_sign_digest" and "sss_asymetric_verify_digest" in ex_sss_ecc.c I can see values around 80ms. Applying the same principle to the calls in file "ex_sss_rsa.c" I end up with values around 4 seconds.
Below you can find the information of my SE050 when executing the example "se05x_Get_Info" and the output of “ex_rsa”.
       App:WARN :#####################################################
       App:INFO :Applet Major = 3
       App:INFO :Applet Minor = 1
       App:INFO :Applet patch = 0
       App:INFO :AppletConfig = 6FFF
       App:INFO :With    ECDAA
       App:INFO :With    ECDSA_ECDH_ECDHE
       App:INFO :With    EDDSA
       App:INFO :With    DH_MONT
       App:INFO :With    HMAC
       App:INFO :With    RSA_PLAIN
       App:INFO :With    RSA_CRT
       App:INFO :With    AES
       App:INFO :With    DES
       App:INFO :With    PBKDF
       App:INFO :With    TLS
       App:INFO :With    MIFARE
       App:INFO :With    I2CM
       App:INFO :SecureBox = 010B
       App:INFO :Tag value - proprietary data 0xFE = 0xFE
       App:INFO :Length of following data 0x45 = 0x45
       App:INFO :Tag card identification data (Len=2)
                        DF 28
       App:INFO :Length of card identification data 0x46 = 0x42
       App:INFO :Tag configuration ID 0x01 = 0x01
       App:INFO :Length configuration ID 0x0C = 0x0C
       App:INFO :Configuration ID (Len=12)
                        00 04 A1 F4             45 88 4F 17             E5 19 C0 69
       App:INFO :OEF ID (Len=2)
                        A1 F4
       App:INFO :Tag patch ID 0x02 = 0x02
       App:INFO :Length patch ID 0x08 = 0x08
       App:INFO :Patch ID (Len=8)
                        00 00 00 00             00 00 00 01
       App:INFO :Tag platform build ID1 0x03 = 0x03
       App:INFO :Length platform build ID 0x18 = 0x18
       App:INFO :Platform build ID (Len=24)
                        4A 33 52 33             35 31 30 32             31 45 45 45             30 34 30 30
                        BC 03 04 79             33 8D 18 10
       App:INFO :JCOP Platform ID = J3R351021EEE0400
       App:INFO :Tag FIPS mode 0x05 = 0x05
       App:INFO :Length FIPS mode 0x01 = 0x01
       App:INFO :FIPS mode var = 0x00
       App:INFO :Tag pre-perso state 0x07 = 0x07
       App:INFO :Length pre-perso state 0x01 = 0x01
       App:INFO :Bit mask of pre-perso state var = 0x00
       App:INFO :Tag ROM ID 0x08 = 0x08
       App:INFO :Length ROM ID 0x08 = 0x08
       App:INFO :ROM ID (Len=8)
                        2E 5A D8 84             09 C9 BA DB
       App:INFO :Status Word (SW) (Len=2)
                        90 00
       App:INFO :ex_sss Finished
ex_rsa
       App:INFO :PlugAndTrust_v02.10.02_20190809
       App:INFO :Running ./ex_rsa
       App:INFO :If you want to over-ride the selection, use ENV=EX_SSS_BOOT_SSS_PORT or pass in command line arguments.
       sss:INFO :atr (Len=35)
                        00 A0 00 00             03 96 04 03             E8 00 FE 02             0B 03 E8 08
                        01 00 00 00             00 64 00 00             0A 4A 43 4F             50 34 20 41
                        54 50 4F
       sss:WARN :Communication channel is Plain.
       sss:WARN :!!!Not recommended for production use.!!!
       App:INFO :Running RSA Example ex_sss_rsa.c
       App:INFO :Do Signing
       App:INFO :digest (Len=32)
                        00 01 02 03             04 05 06 07             08 09 0A 0B             0C 0D 0E 0F
                        10 11 12 13             14 15 16 17             18 19 1A 1B             1C 1D 1E 1F
msec time is 4282.000000
       App:INFO :Signing successful !!!
       App:INFO :signature (Len=256)
                        7F D3 4E A2             2F F7 BE B9             DC 73 F0 60             F5 B8 16 1C
                        27 B7 A6 38             D1 67 C1 6A             1D D0 5D 9F             5E 16 C0 E8
                        DE 36 F1 45             6C 45 0A C1             63 21 A0 B2             0E 94 ED B4
                        65 5F 9D 2E             5F 65 47 18             1B CB 10 41             87 BD 5B 6F
                        9E 13 B4 3A             44 A3 67 B5             46 9E 97 84             88 C1 F7 5C
                        2F AE B8 91             53 2B D2 84             6B 8E 9B B9             6E F3 B5 AE
                        51 50 16 DB             16 A3 1A 1C             93 D1 F6 C4             C6 CB 1F 83
                        0E 31 E2 39             19 3E F0 E5             B9 B3 9A D8             CF BE 93 4A
                        7B 53 83 1F             62 DB A8 50             F2 4D 0D AF             8F 8C D6 57
                        3B 9C C3 34             DF E6 BC E1             31 6A 98 87             62 54 53 12
                        5C 1F 21 B5             12 B3 04 89             4D A7 4B 83             97 E7 9D 50
                        2D 91 F8 0C             29 73 38 B8             62 2B BC B0             F1 F6 F2 A2
                        BF E5 BE 41             91 EF D9 52             BA BC 0F D8             3E 11 ED 90
                        47 E0 D5 0C             ED 84 EF 75             F0 96 3B B0             32 97 AA 84
                        B0 FF 25 0A             CB A2 8C D4             0D 0F F7 5F             BC 1A 8B 87
                        AE 4E F8 42             3C E1 FE 44             B1 E0 52 66             E1 D0 A3 64
       App:INFO :Do Verification
msec time is 761.000000
       App:INFO :Verification successful !!!
       App:INFO :ex_sss_RSA Example Success !!!...
2,291 次查看
Kan_Li
Do you have the test log? I will try to reproduce this issue here.
Kan
