today we can use secure element with success in embedded system (yocto project).
But we started migration to use kirkstone that support openssl 3.0.13.
We would like to know if secure element supports openssl 3.0.13.
Thanks in advance,
Cristiane Bellenzier Piaia
Hi @CristianeBP ,
Yes , the latest MW can support openssl 3.x based on OpenSSL provider, please kindly refer to https://www.nxp.com/webapp/Download?colCode=SE05x-PLUG-TRUST-MW&appType=license for details.
Kan
Good afternoon Kan_Li,
thank you for the reply.
I got the code sent by you but I not able to build using PTMW_Applet = SE05X_B.
For now, this is the error:
[ 51%] Building C object sss/plugin/openssl_provider/CMakeFiles/sssProvider.dir/provider/src/sssProvider_main.c.o
/home/maxwell/SE05x/simw-top/sss/plugin/openssl_provider/provider/src/sssProvider_main.c:127:35: error: ‘sss_ecdh_keyexch_functions’ undeclared here (not in a function)
127 | {"ECDH", "provider=nxp_prov", sss_ecdh_keyexch_functions}, {NULL, NULL, NULL}};
make[2]: *** [sss/plugin/openssl_provider/CMakeFiles/sssProvider.dir/build.make:128: sss/plugin/openssl_provider/CMakeFiles/sssProvider.dir/provider/src/sssProvider_main.c.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:1695: sss/plugin/openssl_provider/CMakeFiles/sssProvider.dir/all] Error 2
Using PTMW_Applet = SE050_E works correctly.
Hi @CristianeBP ,
It was confirmed that this issue has been fixed in the upcoming ver 4.5.1.
Kan
Hi @CristianeBP ,
Yes, I can reproduce it here, and have reported to the MW team. I will let you know when there is any progress.
Thanks for your patience!
Kan
