Pin difference Edgelock SE050 vs SE051
Search instead for
magr0433
Hello all,
I am considering updating from SE050 to SE051 in a product I am designing. I have found a difference in how some of the unused pins should be connected in the datasheets. The pin that is affecting me is pin 14. Here is the difference:
ChipSymbolPinDescription
SE050ISO 7816 RST_N14ISO 7816 reset input low active
SE051ISO 7816 RST_N14ISO 7816 reset input low active, if not used then connect to Vcc or Vss
My question is if it is OK to leave pin 14 floating on SE051, because that is how we designed the PCB for SE050.
Anonymous
Deactivated User
hai magr0433,
  In both SE050 (Page 13)and SE051 (Page 18)data sheet is mentioned "ISO 7816 reset input low active, if not used then connect to Vcc or Vss" statement. If it work with SE050 means leave as its because Both IC have same RESET operation.
Kalaimani Arumugam
Anonymous
Deactivated User
hai magr0433,
Kalaimani Arumugam
magr0433
Hello Kalaimani and thank you for your answer.
Maybe I have an old revision of the datasheet: Rev. 1.3 — 7 June 2019
I think I will try to keep it as it is because it has worked so far.
Markus G
Kan_Li
Hello @magr0433 ,
For RST pin unused case, it would be the best to pulldown to GND to mark pin inactive.
Kan
