Dear Support team,
We are developing CLRC663 application with using NFC Library v05.22.00.
We have a problem with reading Mifare DESFire EV1 tag.
We issue DESFire tag with 3KDES encryption, and we use following API:
phStatus_t phalMfdf_AuthenticateISO(
void * pDataParams,
uint16_t wOption,
uint16_t wKeyNo,
uint16_t wKeyVer,
uint8_t bKeyNoCard,
uint8_t * pDivInput,
uint8_t bDivLen
When the program run on FRAME Command and go to the step- [Get the encrypted RndA' into bWorkBuffer], it will occur the error: [MF DF Current authentication status does not allow the requested cmd].
If wee use DES encryption tag, then it will be OK.
We want to know the reason why cause this error. Or there is needed parameters initialization we miss?
Following code we wrote for 3KDES and doesn't work:
case KEY_TYPE_3KDES:
Is_Gigatms_Mdf_Setkey(g_tRegisters.s2.DF.bKey ,PH_KEYSTORE_KEY_TYPE_3K3DES ,STORE_KEYNUM_3K3DES);
status = phalMfdf_AuthenticateISO(psalMFDF, PHAL_MFDF_NO_DIVERSIFICATION, STORE_KEYNUM_3K3DES, 0, 0, NULL, 0);
break;
Following code we wrote for DES is working fine:
case KEY_TYPE_DES:
Is_Gigatms_Mdf_Setkey(g_tRegisters.s2.DF.bKey ,PH_KEYSTORE_KEY_TYPE_DES ,STORE_KEYNUM_DES);
status = phalMfdf_AuthenticateISO(psalMFDF, PHAL_MFDF_NO_DIVERSIFICATION, STORE_KEYNUM_DES, 0, 0, NULL, 0);
break;
Following code we wrote is used to set key:
bool Is_Gigatms_Mdf_Setkey(uint8_t *pKey, uint8_t bKeyType, uint8_t bKeyName)
status = phKeyStore_FormatKeyEntry(psKeyStore, bKeyName, bKeyType);
if ((status & PH_ERR_MASK) != PH_ERR_SUCCESS)
return FALSE;
/* Set Key Store */
status = phKeyStore_SetKey(psKeyStore, bKeyName, 0, bKeyType, pKey, 0);
return FALSE;
return TRUE;
Thanks for viewing this topic.
David Huang
