In the Safety Manual Addendum there is an assumption with ID 1248005 that the TEST input is tied to ground during boot and normal operation mode.
The question is what Test input or Test pin is this referring to?
Thank you,
John H. Floros
已解决! 转到解答。
Hello John,
This assumption ID 1248005 has been removed from the updated list of assumptions since the S32K3 doesn't include a Test input pin. This would get reflected in the next draft of the Safety Manual. Hope this clarifies.
Thanks and Regards,
Avni
Hello John,
Thanks and Regards,
Avni
