QFN32 pin terminal open/short test results
787件の閲覧回数
hiroyuki_murako
Hello, I am using the S32K116 QFN32 pin.
Could you please give me the test results of the open/short test of the terminal of the QFN32 pin?
Potential Failure Mode
 Pin Open
 Pin Shorted to Ground
 Pin Shorted to adjacent pin (N+1)
 Pin Shorted to Vdd (5V)
S32K116_32qfn
Pin Name
DEFAULT
3
VDD
VDD
4
VSS
VSS
5
PTB7
EXTAL
6
PTB6
XTAL
20
VSS
VSS
21
VDD
VDD
28
PTA10
JTAG_TDO
29
PTC5
JTAG_TDI
30
PTC4
JTAG_TCLK/SWD_CLK
31
PTA5
RESET_b
32
PTA4
JTAG_TMS/SWD_DIO
タグ(2)
781件の閲覧回数
Yashwant_Singh
Hi Hiroyuki,
1. The JTAG and Reset pins are not modelled explicitly in the FMEDA.
2. The VDD and VSS pins are modelled in the FMEDA and their Failure modes can be seen in the static version under the name of "Package Contacts"
3. NXP's assumed safety concept recommends not to use XOSC as the system clock source and instead use FIRC. (see the attached Safety Manual Snippet). Therefore the XOSC (and hence its package contacts) are marked NSR in the FMEDA and so not reflected in the Static version of the Clock FMEDA.
Hope this helps!
Thanks!
-Yashwant.
782件の閲覧回数
Yashwant_Singh
Hi Hiroyuki,
Hope this helps!
Thanks!
-Yashwant.
778件の閲覧回数
hiroyuki_murako
Dear Yashwant,
Thank you very much for your notice and support.
I was able to understand the content.
Thanks!
