what's the Pins status when MCU S32K116 reset before port initialitation,
1,390 次查看
asd046012
Hello
    when MCU S32K116 reset, before port initialization, what's the Pins status?  the direction of pins  is output status?  the output level is high level?
1,381 次查看
Robin_Shen
Hi asd046012,
All pins keep the default state, this is, Analog pins remain the analog function, digital pins are disabled, in other words in high impedance(tri-stated).
9 Unused pins.png4.4 Default pad state.pngTable 4-1. Pad Signal description.png
Robin
1,382 次查看
Robin_Shen
Hi asd046012,
Robin
1,169 次查看
luca_toso
Hi Robin,
I know that I am a bit late in the topic but I want a clarification if possibile:
When the MCU is KEPT in RESET, what is the status of the ports?
I'm asking because the datasheet specifies the status out of reset or port not initialized.
Also, if the MCU is NOT powered (e.g. FS applications that cut off MC power) what is the status of the mcu ports?
Thanks and K.R.
