Hello
when MCU S32K116 reset, before port initialization, what's the Pins status? the direction of pins is output status? the output level is high level?
Solved! Go to Solution.
Hi asd046012,
All pins keep the default state, this is, Analog pins remain the analog function, digital pins are disabled, in other words in high impedance(tri-stated).
Robin
Hi asd046012,
Robin
Hi Robin,
I know that I am a bit late in the topic but I want a clarification if possibile:
When the MCU is KEPT in RESET, what is the status of the ports?
I'm asking because the datasheet specifies the status out of reset or port not initialized.
Also, if the MCU is NOT powered (e.g. FS applications that cut off MC power) what is the status of the mcu ports?
Thanks and K.R.
