manage ADC on dual core(S32K324)
471件の閲覧回数
michelet1
Good morning everyone,
i was analyzing code of the following ref design:
https://www.nxp.com/document/guide/getting-started-with-the-mctptx1ak324-evaluation-board:GS-MCTPTX1...
and in this case ADC channels were all associated with core0.
My question is the following: is it possible to separate ADC instances so as to have for example ADC0 on core0 and ADC1,ADC2 on core1? or is there some limitations?
Thanks in advance for any help and guidance.
444件の閲覧回数
_Leo_
Thank you so much for your interest in our products and for using our community.
In MCTPTX1AK324 demo code, ADCs 0/1/2 were managed by core 0 and core 1 could get conversion results by sharable memory. This configuration were for application purposes.
However with the XRDC you can manage access control between masters (cores and noncore masters) and targets (memories and peripherals) by placing them in domains. You can read more about it in Chapter 19 Extended Resource Domain Control from reference manual.
Hope it helps you.
Have a nice day!
3 返答(返信)
445件の閲覧回数
_Leo_
Hope it helps you.
Have a nice day!
426件の閲覧回数
michelet1
Good morning,
thanks for your suggestions.
I looked at chapter 19 of the reference manual but a doubt arose: i can dedicate peripheral instances to specific cores( e.g. ADC0 for core0 and ADC1,ADC2 for core1) and then exploit XRDC to create domains so that, for example , core1 cannot access ADC0 because it is already allocated on core0, is this reasoning correct?
thanks again for the help
best regards
415件の閲覧回数
_Leo_
Your understanding is correct!
