how to set systick to get microsecond(us) delay in use s32k144
6,695 次查看
jinshuaixu
Contributor V
hello
        S32DS software has the  delay function.the example project that s32ds provide is millisecond(ms) delay "OSIF_TimeDelay(1)", now I want to use microsecond(us) delay ,how l acquire this function ,please help me if you know how to configuration register or give me example project. thank you.
5,934 次查看
danielmartynek
The OSIF implementation can be found in the osif_baremetal.c file.
The reload value of the SysTick is the core frequency divided by 1000, that means that the Systick interrupt is called every 1ms and increment the s_osif_tick_cnt counter.
The counter is then read and compered by the OSIF_TimeDelay() function.
If the core frequency was divided by 10000, the counter would increment every 100us (OSIF_TimeDelay(1) = 100us).
The SysTick description can be found in ARM documentation.
Cortex™-M4 Devices Generic User Guide
Section 4.4 System timer, SysTick
4 回复数
2,684 次查看
Eashwar
Hi Daniel,
I also have the same requirement to generate microsecond delay, but my Controllers is MPC5777C. OSIF is connected to PIT(default) and its frequency is 100MHz. I have also followed your instructions and updated divider value in "static inline void osif_UpdateTickConfig(void)" function, as shown in image below.
The problem is when I call "OSIF_TimeDelay(1)" program pointer is struck in  "osif_Tick()".
Kindly provide suitable solution.
Eashwar
5,935 次查看
danielmartynek
2,704 次查看
Eashwar
Hi Daniel,
Eashwar
5,934 次查看
jinshuaixu
Contributor V
thank you for you response, l have test the way you you offer,the result is correct.
