how to make a easy delay function by using the S32K144EVK board.
Guofred
i want to make a easy delay function for the blinking LED, i found this function doesn't have execute and  jump the code end line. the details as below.
the attachment is the source code, would you like kindly help to share your comments or provide your blinking LED code for reference, thanks.
Best regards.
Guofred
Senlent
Hi@Guofred
please refer to belowing picture.
BR!
     Jim,
Senlent
Hi@Guofred
you can take a look at belowing function
file osif.h
* @brief Delays execution for a number of milliseconds.
* @param[in] delay Time delay in milliseconds.
void OSIF_TimeDelay(const uint32_t delay);
BR!
     Jim,
Guofred
Hi @Senlent ,
Thanks for your kindly help.
would you like kindly help to share your code for reference, may be osif.h and osif.c are need to add our project, i can't use this function directly, thanks.
Best regards.
Guofred
Senlent
Hi@Guofred
BR!
     Jim,
Guofred
Hi @Senlent ,
Thanks for your patience and kindly help.
Best regards.
Guofred
