arm-none-eabi-gcc.exe: error: out/*.o: Invalid argument
1,775 次查看
lb28
I am using:
SW32K1_RTD_4.4_1.0.1
I want to generate the .elf file using the MCAL in command prompt.
Here's my 'project_parameters.mk' file.
I keep getting this error when using 'make build' command
Thank you in advanced.
5 回复数
1,566 次查看
stanleylin0729
Hi @lb28 ,
I encountered the same problem too, and I found a straightforward solution, hope it will work for you.
I used Python script to list all the .o files in the out/ folder, and declare a variable like this
Then, replace $(ODIR)/*.o by $(OUTS)
The attached file is the Python script, run it in /Dio_ToggleLed_S32K144
782 次查看
huqifan
This works for me, thanks!
Another way is to modify the Makefile directly as shown below:
@$(LD) -Wl,-Map,"$(MAPFILE)" $(LDOPT) -T $(LINKER_DEF) $(ODIR)/*.o -o $(ODIR)/$@
@$(LD) -Wl,-Map,"$(MAPFILE)" $(LDOPT) -T $(LINKER_DEF) $(wildcard out/*.o) -o $(ODIR)/$@
1,749 次查看
namnguyenviet
Hello @lb28,
Not sure what is the reason for that. Could you try the following change and share with me the log after linking?
Let's see what could be invalid.
Nam
1,746 次查看
lb28
I've made the changes you've requested. Here's my project.
I'm still getting the same error.
1,712 次查看
namnguyenviet
Hello @lb28,
Sorry for late reply. Unfortunately, I couldn't reproduce the issue. Could you try to change from slash (\) to backslash (/) in each of the paths and try again? It worked like that in my site:
Nam
