Unable to use round function
DemaQasem
I am implementing a project on S32K144 using the S32DS IDE v3.4, when I use the "round" function and build the project I get the error  :
even though I made sure to include the math.h library
any reason for that  ?
Thank you.
Tags (2)
jiri_kral
math.h is only header file for math library. You need to add libm.a library into your project in project properties:
jiri_kral
DemaQasem
thank you so much ! it worked.
