Hi, I am unable to generate the project after importing the example project from "SW32K3_RTD_4.4_2.0.1"
After generating the project, the output folder remains empty. no config files are generated. Please provide some solution for this.
@mikedoidge Please help
Solved! Go to Solution.
Hi yash_bhatnagar9,
You can click right on the project's name and you can see that the config files were generated at the path below:
If you want to generate config files to the "output" folder => you can modify the generation path as the image below:
Dan
Hi yash_bhatnagar9,
Dan
