Trigger ADC from both BCTU and other HW source S32K344
oskarjohansson
Hi, I want to trigger one ADC, both from BCTU and from other hw trigger source.
The BCTU is triggered from a eMIOS channel to enable center-aligned ADC reading in a PWM pulse and having the data into a FIFO.
I also need to trigger a group on the same ADC which I want to be triggered from a hw source, such as a PIT.
But when I initialize the BCTU with Adc_EnableCtuControlMode( ADC ) I cannot longer trigger the ADC, as I can read in the RTD ADC user manual 3.6.3 BCTU control mode.
Is there any other way to be able to use both the BCTU and a HW trigger source simultaneously?
Oskar Johansson
_Leo_
Thank you so much for your interest in our products and for using our community.
If you are in BCTU control mode, only the BCTU can start a conversion. All other trigger sources are ignored, including HW trigger sources.
Hope it helps you.
Have a nice day!
